04 tranny onto 01 chassis and motor?
Old Sep 28, 2012 | 02:13 PM
BrandonIRON's Avatar
4th Gear
Default 04 tranny onto 01 chassis and motor?
is there any problems with installing an 04 tranny and transfer case into an 01 d2?
Old Sep 28, 2012 | 03:38 PM
lr2001silver's Avatar
Banned
Told you i have a 01 here in town for you. I also have the rest of the parts your looking for dude!
Old Sep 28, 2012 | 04:20 PM
jafir's Avatar
Drive shafts are different lengths. Get those too. Transfer case doesn't have a safety solenoid in it. Oh and get the 04 transfer case shifter too. And sell it to me.
Old Sep 28, 2012 | 04:47 PM
Rovin4life's Avatar
The cable is different lengths as well depends on the vin though.
Old Sep 28, 2012 | 07:10 PM
Banned
Should just buy mine for a direct fit:-)
Old Sep 28, 2012 | 11:25 PM
4th Gear
hey silver this guy only wants only 500 bucks for the transmission and transfer case, truck had only 90,000 on it. are both driveshafts different lenghts?
Old Sep 29, 2012 | 01:16 AM
Banned
Yea that cause he knows your going to have to make adjustments to make his stuff work in your 01. Not really worth the headache. 90,000 doesnt really matter call some tranny shop they will all tell you they never had a rover come in to the shop because of a transmission problem. Trans in these trucks don't just fail, however they were not designed to have the **** beat out of them by the drive shaft.
Old Sep 29, 2012 | 07:37 AM
amgraves's Avatar
The transmission is the same. Its the case that is different. I've done the comparison before. The transmission is the same old ZF 4HP24 that its always been. And yes, the shafts themselves are different lengths for 2003 and 2004. If I remember correctly the front shaft is shorter and the rear one is a little longer.
Old Sep 29, 2012 | 11:31 AM
4th Gear
thanks you the info fellas, i have the original transfer case, will it bolt up to the new tranny, if so who wants to buy an 04 transfer case? ill see if hey has the shifter too?
Old Sep 29, 2012 | 11:39 AM
Banned
Ill sell you a transmission and shift cable for $400 you wont find a better deal than that.
