045 - Left Rear Sensor Bad Output
Old Sep 2, 2016 | 03:57 PM
coors's Avatar
Default 045 - Left Rear Sensor Bad Output
I've been throwing ABS fault 045 "left rear sensor low output" for a few days.
This afternoon, after clearing the code - it returned. This time as "left rear sensor Bad Output". I decided to swap the sensor with a known good one from my parts truck And the first bump I hit after install during a "test drive" the "four Amigos" illuminated again. Same code, 045, "left rear sensor bad output".
It seems every time I hit a bump in the road the ABS TC HDC and Brake light illuminate.
I'm stumped...
I performed a resistance test on the replacement sensor prior to installing, I think it read roughly 1020 ohms. In the upper limits of specified range. I think optimal range is within ~950 - ~1120 ohms. The reading bounced around a bit as I tapped the sensor against metal...
What should I be looking for?
* trace wire back to SLABS - inspect for ground faults along chassis?
* bad wheel hub? What makes up the hub? A bearing and casing? I don't believe the bearing is worn.
* fault at connector at SLABS unit?
brooksa
Aug 1, 2016 04:37 AM
hossiena
Jul 18, 2013 10:48 PM
Rickey_240
May 5, 2013 08:26 PM
VT_estey
Jul 9, 2011 06:57 PM
grendel
Jun 8, 2009 04:13 PM
