04'Disco3 Problem??
Old Sep 22, 2007 | 07:51 AM
yapck's Avatar
3rd Gear
Default 04'Disco3 Problem??
Hi, I'm new member and having problem with my discovery each time when i shift from reverse to 'd' or when 'd' to reverse some noise coming from below the engine, can anyone help??
Thanks in advance.
ck
Old Sep 22, 2007 | 08:02 AM
Default RE: 04'Disco3 Problem??
First you have a Disco 2 not a 3.
How many miles on your truck?
Have you had your front drive shaft rebuilt with new greasiable u-joints?
Old Sep 22, 2007 | 08:27 AM
Darover's Avatar
A description of the noise would probably help too. knocking, cracking, loud tud, clinging.......you know wadamean.
Old Sep 22, 2007 | 08:28 AM
yapck's Avatar
3rd Gear
Default RE: 04'Disco2 Problem??
Hi Mike Thanks for reply.Sorry for the mistake. Now is 110. Have not rebuild front shaft. Any solution?
Old Sep 22, 2007 | 08:34 AM
yapck's Avatar
3rd Gear
Hi Darover, The noise like something cracking only upon shifting before moving. After moving the vehicle runs smoothly without any noise.
Old Sep 22, 2007 | 11:43 AM
Darover's Avatar
Don't know how strong you are, but diveunder while the vehicle in park and not running and try turning the driveshaft as hard as you can on each side to see if you have any play in the u-joints. The lower frontu-joint can be lubed and has a grease fitting. Try lubing that. As Mike said, greasable front u-joints are an excellent idea to avoid failures and I'm sure he'll tell you some more when he comes back.
How much mileage on the truck and are you still under warranty, are other relevent informations needed to coach you right.
Could also be your brakes making that noise.
Was forgetting to ask if you checked the transmission oil level ??
blaster1232
Jul 13, 2015 04:37 PM
getaround
Sep 26, 2013 07:09 PM
disco2003
Feb 25, 2013 12:58 PM
JohnCardiff
Nov 8, 2009 12:54 PM
dino
Feb 12, 2005 05:13 AM
