disco3 front seats
Old Feb 22, 2013 | 02:46 PM
disco2003's Avatar
Default disco3 front seats
I have read about seat heater problems but I have seats that won't move
I checked the relays under the seat fuses etc seam ok when i ground the relay under the left seat i can get the seat to move forward and back.
somebody has run from what i can see a jumper wire i suspect from the seat down the center console into the dash looks as though going to the climate control? does anybody have any thoughts would this problem still be needing a hard re set?
Thanks
H
Old Feb 22, 2013 | 02:56 PM
Wiring diagrams attached, some variation with/without memory seats
File Type: pdf
Old Feb 25, 2013 | 12:58 PM
disco2003's Avatar
Thank's Savannah
The diagram did the trick removed whomevers by pass / fix that didnt work found and fixed ground to relay.
blaster1232
Jul 13, 2015 04:37 PM
getaround
Sep 26, 2013 07:09 PM
JohnCardiff
Nov 8, 2009 12:54 PM
yapck
Sep 22, 2007 11:43 AM
dino
Feb 12, 2005 05:13 AM
