1 amigo, just won't go away
Old Jun 13, 2017 | 11:47 AM
Twix's Avatar
Default 1 amigo, just won't go away
I foxed my 3 amigos last summer, and now one has come back. The HDC light is on and the code tells me it's brake lamp circuit issues.
I checked the wiring for my brake system and found a wire that goes through the rear tailgate loom that was nicked, so I fixed that wire and the loom. I checked the fuse and obviously it's fine since the lights work.
I've read that the relay could be bad, but wouldn't that cause my lights to not turn on when I hit the pedal? I've also read that the HDC keeps an eye on fluid temps, where is that sensor located?
I have extended brake lines I have to install, just waiting for the penetrating oil to work its way through the threads. Then I'll do a full fluid flush.
Anything else I need to look at? I'd like this light gone so I have a clean dash again.
r.serio
Oct 11, 2013 09:55 AM
Princess
Jul 4, 2009 12:24 PM
WhiteLRII
Nov 20, 2008 08:02 AM
Disco Mike
Oct 16, 2007 05:53 PM
