11 Fault Codes - Discovery II
Old Jun 1, 2010 | 04:49 PM
bocamar's Avatar
Default 11 Fault Codes - Discovery II
Hello Guys
My discovery Series II 2000 with 180K on the clock even though still running great but after regural oil change and minor maintenance the mechanic wrote me down 11 fault codes as the services engine soon was on:
p1590 Manf Cntrl Veh Spd Idle Speed Control Aux Inpunts
p0420 Catalyst Efficiency Below Threshold (bank 1)
p1300 Manf Control Ignition sustem or misfire
p0308 Cylinder 8 Misfire detected
p1174 Manf Control fuel air matering
p0446 Evap Emission Control System vent Circuit Malfuntion
p1173 Manf Control Fuel Air Matering
p1171 Manf Control Fuel Air Matering
p0303 Cylinder 3 misfire detected
p0133 O2 sensor CKT slow response (bank 1 sensor)
p0306 Cylinder 6 misfire detected
As I'm out of the states, pretty sure that I need to buy a new parts, please somebody could advise me here
Thanks a lot
Charlie
Old Jun 2, 2010 | 11:51 AM
blast20's Avatar
Well, you should definitely start by replacing your Mass Airflow Sensor, as that "can" be the cause of a good 9 of the 11 codes. Don't buy from the dealer - order from roverguy.com as he has them for about $130. good luck -
Old Jun 2, 2010 | 12:04 PM
lipadj46's Avatar
You have a smorgasbord of issues. But like the previous poster said. Start with a new MAF and clear the codes and see what comes back. 1590 is your 3 amigos, 0133 probably means you will need at least one new O2 sensor. Hopefully the misfires and cat code will go away after the MAF. You purge leak hopefully was at one point a loose gas cap. If you have not a tuneup lately new plugs and wires are a good idea also.
Old Jun 2, 2010 | 03:26 PM
How long has the check engine light been on?
If for awhile, I would clear the codes, drive it for a couple of hours and then when the light comes back on you can deal with the current codes.
How long since it was tunes along with new plug wires and have the 02 sensors ever been changed?
Old Jun 6, 2010 | 01:06 PM
bocamar's Avatar
Default Maf
Thanks for your suggestion, however, I replace the MAF 7 months ago...based on that what other issues could be?
Old Jun 6, 2010 | 01:08 PM
bocamar's Avatar
Default wires and codes
Thanks Mike
Last tune up with 122K - almost two months with the engine light on, I will clear the codes and see what codes came up.
Old Jun 6, 2010 | 04:49 PM
lipadj46's Avatar
Was it a genuine rover MAF?
Old Jun 7, 2010 | 09:02 AM
hilltoppersx's Avatar
+1 was it a genuine rover MAF in teh Bosch LR box?
Old Jun 7, 2010 | 09:08 AM
okdiscoguy's Avatar
He has over 180K on the ticker and no one is asking about O2's? When were they replaced? If never, I would start there....
Old Jun 7, 2010 | 09:40 AM
bocamar's Avatar
Default Maf
I bought it fram Atlantic
ERR7171G Mass Air Flow Sensor $217.95
