12V and no blow!
Old Feb 16, 2014 | 03:15 PM
Caleb.hunter's Avatar
Unhappy 12V and no blow!
Ok I've read just about every post I could find, but I haven't found the answer yet. I've got a 2002 Disco II. The heater blower motor stopped running one day. The fuses are good, I'm getting 12V at the connector, the blower runs at max when I connect it direct to the battery and I can't find any burnt connectors under the glove box.
Is there an amperage problem? Don't tell me I have to start chasing wires. It's about to get HOT in Corpus Christi, TX! Help!
Old Feb 16, 2014 | 06:24 PM
PalmettoDisco's Avatar
LOTS of posts about this. Probably cracked solder inside the fuseblock, interior or under hood or both. Solder is passing 12V until put under load, the crack cannot handle the amps. New fuseblock or bypass as stated in numerous posts.
Old Aug 31, 2015 | 05:08 PM
Ended up being the HVAC control head.
thearmlesswonder
May 2, 2013 10:00 PM
newBrover
Jul 25, 2010 04:57 PM
Eak69
Apr 4, 2010 11:52 AM
mrossipir
Jun 26, 2009 04:42 PM
Phototone
Apr 16, 2008 01:14 AM
