130k on the clock, DII what breaks next?
Recently been through a power steering pump and a crank shaft position sensor.
Wondering what you guys have had fail around this many miles. I'm trying to put together a spare parts list for the Baja (the CSPS had me stuck for a day or two the last time down).
I'm thinking I need to carry a fuel pump, what say you?
Thanks!
--rob
Thanks!
--rob
Won't bother carrying another CSPS, as that's a new part. Driveshaft, head gaskets done long ago.
Seriously, DII Fuel pumps never fail?
The life of all parts is relative to the part.
My water pump is original with just shy of 200,000 miles on it.
My original fuel pump went out around 180,000 miles.
But if you cruise the forums you will find people with bad water pumps at 100k and bad fuel pumps at 120k.
If you continually run your gas tank in the 1/4 or less range your fuel pump will not last as long.
It is a electric pump, heat kills electric motors. The fuel pump is submerged in the gas. Once it gets down below the 1/2 mark the fuel pump starts to be exposed, the less fuel the more exposed it is.
The more exposed the more heat, the more heat the shorter the life.
Live in the desert and run your gas tank empty every week, fuel pump lasts maybe 100k.
I never run my gas tank below a 1/2 tank unless I am on a trip.
Water pump bearings are lubricated by the lubricant in the engine coolant.
Neglect your coolant and you not only increase your chances of lime and scale buildup inside your cooling system but you are also running the water pump bearings with no lube.
As for the signs of a failing fuel pump, hard to start in the morning is the number one sign.
joshspartanlee
02-23-2013 09:10 PM
CL500
11-01-2010 10:19 PM
CL500
11-01-2010 09:00 PM
