15 codes triggered in one day!?!
Old Jun 6, 2017 | 10:51 PM
Jsivey's Avatar
Default 15 codes triggered in one day!?!
Brief Setup - I was driving down the interstate. Doing a little over 70mph. The car made a short lurch like it was blocked up. Then things were fine. Not long after that, my Ultra Guage showed 15 codes and my CEL came on.
SIDE NOTE: My Ultra Guage stopped measuring current MPG and average MPG right after the "lurch".
I made a list of all the codes, some of which are o2 sensor related so I'm not sure if those are/could be triggered by the other problems.
To get the full idea of what happened I'm going to give you ALL the codes that triggered. I researched them already, but I want to see what you guys think.
My biggest question is once I figure out what these are, can I do the repair myself? I'm not a mechanic, but I have replaced the upper IM gasket, coil packs, wires and plugs on my own so I'm capable of doing more complicated repairs.
Here are the codes:
P1451
P0414
P0445
P0448
P0102
P0340
P0134
P0135
P0154
P0155
P0141
P0161
P0159
P1884
P1482
There are a couple of pending codes, but they all relate to the O2 sensors so that's the least of my worries.
Old Jun 7, 2017 | 11:01 AM
LR03NJ's Avatar
Could be just a loose connection of a tube of plug or harness around your SAI if you have it.
Old Jun 8, 2017 | 10:54 AM
Alex J's Avatar
Best thing to do is write down the cods, which you have done, check for obvious problems like loose battery cable connections, then I would clear the faults and keep driving it like you normally would and see if any of the same faults come back.
Old Jun 8, 2017 | 11:27 AM
Friday Night Disco's Avatar
Did you happen to fill the truck up with gas in the 24hrs prior to this happening?
Old Jun 8, 2017 | 11:29 AM
Jsivey's Avatar
I may have put some gas into it, but I don't think I filled it up. Premium near my house is $2.10. Premium near work is $3.30. I never fill up near work.
One thought went to the gas cap, but I made sure it clicked several times when I filled up this morning.
I do have SAI so I will look it over tonight once I get home and the engine is cooled.
Old Jun 8, 2017 | 11:47 AM
My thoughts as well
Do me a favor...Take your gas cap off and clean it as well as the spout with some scotch brite. Clear the codes and see if they come back.
I was a person that was getting codes similar to the ones you posted AND after cleaning my cap and spout, they never came back.
Worst case scenario, you spend 5 minutes and $2.00 on something that doesn't work
EstorilM
Apr 24, 2016 02:40 PM
flabrit
Oct 17, 2014 10:28 AM
seniordon
Jan 17, 2011 12:26 PM
josho
Jan 3, 2010 05:25 PM
