16 inch steel wheel options / sizes.
Old Apr 20, 2017 | 01:34 PM
Joelhimself's Avatar
Default 16 inch steel wheel options / sizes.
Hello!
I want to replace my stock 18" rims with 16" steel wheels with all terrain tires. This will be for my 04 Discovery with stock ride height. I am seeing 7" and also 8" wide options for steel wheels. Any recommendations or suggestions / pros and cons between the 2 different widths?
Thanks!
Old Apr 20, 2017 | 01:44 PM
Jeff Blake's Avatar
Find out what tire you want first, it will tell you compatible rim widths. In general, 7" = skinny tire, 8" = normal-wide tire
Old Apr 20, 2017 | 02:41 PM
255 65 R16 is the factory size for 16 inch rims on a D2 and is what I am looking at but am interested in suggestions / Pros and cons etc.
Old Apr 20, 2017 | 02:43 PM
Jeff Blake's Avatar
For stock height, you don't have a lot of options. Just stick with 255.
I added a lift and switched from 18's to 235/85R16. Using 16x7 rims. Very happy with it.
Old Apr 20, 2017 | 09:05 PM
Best4x4's Avatar
I ran 265/75R16 BFG KO's on both my 03 D2's back in the day with zero lift. Since they weren't an aggressive tire like a M/T I had no issues at all. Of coarse now I'm sure the OEM springs will have sagged over the years.
Old Apr 21, 2017 | 03:12 AM
The Deputy's Avatar
I guess it depends on what type of steel wheel/rim you're getting and the off-set. Generally, rule of thumb is, for every inch you go up, you widen the stance of the vehicle the same amount. But, since you are staying at a stock height, either rim should work (7in/8in dia). I've ran my wife's 18's on my 01, which has 16 aluminums and notice no significant difference in the two.
As far as pros and cons go...I'm not exact sure what you're looking for? Steel vs aluminum or 18 vs 16?
If it's the latter, I like 16's...they don't look so soccermom/mallcrawler/whoopie. Only put the 18's on mine, to try and eliminate a vibration issue on my wife's discovery. They were back off within a few days on determining they were not the issue.
If it's the former, I have no experience with steel rims on a discovery.
Good luck, with your decision.
Brian.
DiscoRover007
Oct 2, 2023 08:44 PM
dcarr1971
Feb 8, 2013 08:16 AM
Joebern
Jun 21, 2011 05:09 PM
jafir
Feb 14, 2011 12:06 PM
morfa
Aug 27, 2006 01:22 PM
