16mm head gasket
Old Nov 16, 2016 | 09:41 AM
Charlie_V's Avatar
Just to add to PalmettoDisco's note--the best socket to take them off is a 5/8 rough impact socket. Smooth sockets tend to slip. Also, those SAI plugs are going to be in the way unless you use some clever wobble extensions on your socket.
Old Nov 16, 2016 | 09:56 AM
LR03NJ's Avatar
Charlie, thanks. I we used the 5/8 impact socket. Those were tough to get out especially the those at the back of the engine. We took our time with those thinking we might end up stripping the heads.
Old Nov 16, 2016 | 11:11 AM
Charlie_V's Avatar
The back ones are hell. After doing it a few times, I use wobble extensions and get far away from them (like, a couple of feet of extensions). Putting the bolts on is a little easier than getting them off, for some reason.
You'll want to be sure to clean the threads/holes out; coolant and oil gets in them when you pull the heads.
The whole job is a PITA!
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
4x4ron
Apr 24, 2012 03:42 PM
dancedisco
Feb 6, 2012 06:34 AM
jcostello
Nov 2, 2006 10:28 PM
