17 inch aftermarket wheels
Old Dec 7, 2015 | 09:15 AM
Valley Mud's Avatar
Default 17 inch aftermarket wheels
Ok, maybe I'm odd but here goes. I have been looking for the right off road tire for a while. I have found that, in North America anyway, that there are more brand ,model and size options of tire for 17 inch rims than 16s.
I have heard that there are after market wheels with our bolt pattern. I can't find them.
Anyone know where to find 17 inch rims for a Dii?
Thanks.
Old Dec 7, 2015 | 09:22 AM
ZGPhoto's Avatar
For the most part, there are more 16" tire sizes available. Either way, you want all the sidewall you can get.
Old Dec 7, 2015 | 09:27 AM
drowssap's Avatar
nope, if you find a 17 it probably from a freelander.
you can have 16 & 18 in steel for about $150ea
Old Dec 7, 2015 | 10:54 AM
DiscoCam's Avatar
You could also get 17" steel rims.
Old Dec 7, 2015 | 11:34 AM
Valley Mud's Avatar
where?
Old Dec 7, 2015 | 11:39 AM
DiscoCam's Avatar
Tire Rack has some. You could also get them from Discount/America's Tire, they will install it for you with tires. They will also make sure that your choice or rim and tire is compatable with your D2.
Old Dec 7, 2015 | 12:32 PM
Alex_M's Avatar
Summit Racing has a pretty big selection. Bolt pattern is a 5x4.75, width is 8", backspacing of 3.5-4" is typically a good choice. You'll need new lug nuts.
Old Dec 7, 2015 | 12:52 PM
ZGPhoto's Avatar
Should be 4.72... but I suppose they're just wheels, some variation shouldn't vibrate TOO badly.
Old Dec 7, 2015 | 01:20 PM
Alex_M's Avatar
That's nearly no difference, and if you torque them in the right pattern they will center up. I've talked to a few guys running Cragars with that pattern no problem.
Old Dec 7, 2015 | 02:15 PM
WNYErikDiscoII's Avatar
Former Sponsor
FWIW, I have 16x8 steelies for $75/each brand new from TF. Not aware of any readily available 17s for the D2, or any other rover with the proper pattern.
