1994 Disco I Electrical problem? Say it aint so!
Old May 27, 2009 | 11:11 PM
topfrog007's Avatar
Default 1994 Disco I Electrical problem? Say it aint so!
Hey there everyone,
I have a 1994 Disco V8I which is having an electrical issue that I'm hoping one of you can help with.
My power windows, cruise control, and rear windshield wiper are not working. I checked the owners manual and it says that these 3 components are all on fuse #18. I checked Fuse 18, and it appeared that there was nothing wrong with it.
All I really care about is cruise control, as I'm going on a rather lengthy road trip soon.
Does anyone have any ideas what the problem might be?
TIA
Old May 28, 2009 | 08:48 AM
Rover Chris's Avatar
does your cruise button light up?
I would check every fuse in each fuse box for a place to start.
Old May 28, 2009 | 01:16 PM
topfrog007's Avatar
I checked all the fuses and they all look fine.
The cruise control button does not light up.
What next?
Old May 28, 2009 | 02:06 PM
the cruise control button gets power from the battery with both fuse boxes in line, if the main cruise power button is not lighting up then your problem is in one of the fuse boxes, I would assume that since all of these items that aren't working run off 1 fuse then that would be your problem (either the fuse itself or the wiring associated with it) I would pull and replace the fuse (even if it looks ok cause looks can be deceiving) then maybe try to somehow clean the contacts where the fuse plugs in on both sides (maybe some electronics parts cleaner from radio shack and working the fuse in there a bit). That would be where I would start, then start testing wires for power.
Old May 28, 2009 | 03:27 PM
okdiscoguy's Avatar
Does this thing have an MFU? I know on mine, all of those things run off the MFU. Do a search for multifunction unit. I posted the diagnoatics for it on here somewhere...
Old May 28, 2009 | 05:18 PM
Replace the fuse, it may look fine and still be blown, it is a $.02 item, replace it and report back.
Old May 28, 2009 | 05:53 PM
AK Rover's Avatar
I agree with Spike, replace the fuse even though it looks fine. (Ouch, that hurt to say. LOL)
Old May 28, 2009 | 07:36 PM
topfrog007's Avatar
Hey guys, thanks for the help thus far.
I replaced the fuse with the one for the power windows (which I know works) and still none of the 3 items worked. I checked terminals where you put the fuse into and they look fine too.
What's my next step?
Old May 28, 2009 | 07:46 PM
old gold's Avatar
Do you have a voltmeter?
Check to see if you have 12 volts relative to ground (chassis) at both ends of both fuses.
Old May 28, 2009 | 08:06 PM
topfrog007's Avatar
Not sure when this happened. At some point during all the testing and posting on the forum the power windows and rear windshield wiper decided to work. I didn't notice, because like I said before I was only interested in the cruise control, so that's the only one I was testing (stupid me). So the cruise control button doesn't light up and overall doesn't work, but the power windows and rear windshield wiper now works.
@Old Gold
I only have one of those crappy cheapo voltmeters that just tells you whether or not there's power going to what you touch it with. Doesn't give any voltage readings, just if it's "Hot" or not. I checked both ends of the fuse and they do have power going to them, not sure what voltage though, and unfortunately I have no way of checking ATM.
