1994 - Keyless entry?
Old Feb 25, 2008 | 08:55 PM
dodge_mich's Avatar
Default 1994 - Keyless entry?
Did the 1994 Discovery have keyless entry? I have a spare fob fob, but the programming procedure does not work for it. I know it does have the alarm, so it seems like it should have keyless as well, but I may be mistaken.
Old Feb 25, 2008 | 09:33 PM
Default RE: 1994 - Keyless entry?
The remote might be bad.
Old Feb 25, 2008 | 10:26 PM
dodge_mich's Avatar
At this point, I'm thinking it's only on '96 and up.
I can't even get to the point where I use the remote, following the manual procedure:
1. Starting conditions: ignition off, doors unlocked,
bonnet switch depressed.
2. Carry out instructions 3. to 9. within 8 seconds.
3. Switch ignition ON.
4. Switch ignition OFF.
5. Lock doors.
6. Unlock doors.
7. Release bonnet switch.
8. Switch ignition ON.
9. Switch ignition OFF.
If alarm is correctly accessed, horn will sound and
LED will light. It is now possible to programme two
handsets of correct frequency to vehicle alarm ECU.
This must be carried out within two minutes.
10. Press and hold down button on first handset until
dash LED flashes.
11. Repeat instruction 10. for second handset.
12. The LED will extinguish if both handsets have
been initialised correctly.
Old Feb 26, 2008 | 01:41 AM
RamblingMan's Avatar
My '94 was keyless entry.
93Miata
Feb 12, 2018 03:23 PM
Frank4
Mar 21, 2014 05:21 AM
faith2
Sep 14, 2005 03:04 PM
FORDSTANGER
Aug 9, 2005 01:00 PM
pvalianatos
Mar 12, 2005 05:20 PM
