1995 disco I
Old Aug 29, 2007 | 03:10 PM
shaunRover's Avatar
3rd Gear
Default 1995 disco I
ok I have some issues with my disco that I cant get fixed.
1st- the tach doesnt work at all. I took it to autozone and it tested good and all the wires to the alt are good. what else could it be?
2nd- cruise control doesnt work, all the vac lines are good and connected.
3rd- srs light is on, it blinks for a while then stays on.
4th the rear drivers side window doesnt do anything, stuck in up position.
5th- the rear passenger side window seems to be off the track, I can push it up but fall back down. its open an inch. ZNone of the switches do anything to the windows. I can hear somthing happening to the passenger side rear, like the motor turning but nothing happens!
6th- the engine ticks constantly and has hardly any power. At low speeds it does but at 40 accelerating to 50 unless going down hill it is pathetic!
7th- I cant get the diff lock to engauge.
Old Aug 29, 2007 | 03:41 PM
Default RE: 1995 disco I
So you need alot of answers which I can give you if you give me a call, beats doing alot of typing.
303-862-7680
Colorado between 7 am and 8 pm
dod
63
Nov 30, 2008 09:29 AM
Crashdevil13
May 24, 2007 08:52 AM
TrickyWhu
Mar 9, 2007 11:43 AM
TrickyWhu
Nov 4, 2006 07:50 PM
evoasis
Sep 15, 2006 09:16 PM
