1995 Disco running issues
Old May 10, 2007 | 11:24 AM
Crashdevil13's Avatar
7th Gear
Default 1995 Disco running issues
Greetings all. I am the proud new owner of a 95 Disco and a 96 Disco (parts truck). I am having lots of trouble searching the forums for this problem, I hope someone here can help me out. At idle, the 95 runs very poor. I have changed plugs, wires, cap, rotor, filters, but no change in the symptom. Also, the display on the diagnostic box is showing no codes. Is there a procedure for turnung it on?
Also, is there a new owner FAQ section here? I couldn't find one.
Jeff M.
Columbus OH
Old May 10, 2007 | 02:51 PM
Landzu's Avatar
Default RE: 1995 Disco running issues
Hard to say but you may have a vacuum leak.
Get a can of carb cleaner B-12 and with it running spray it over the
vacuum lines stay away from the Dist cap and spk wires.
The motor will idle up when or if you find the leak.
Old May 10, 2007 | 05:02 PM
7th Gear
Thanks for the idea. I checked this previously, but no leak found. I am suspecting the Idle Control Valve. Anyone have a history of them going bad?
Also, the diagnostic display now works and is giving me code 48. Any ideas?
Jeff M.
Columbus, OH
Old May 18, 2007 | 02:17 PM
cp95disco's Avatar
I'm having mine replaced today as a mater of fact ( idle control valve). Was experiencing a surge of power and drop of power at idle and the occasonal need to restart becuse it would die on me.
Old May 18, 2007 | 10:52 PM
don_r6's Avatar
Code 48 is stepper motor related. Chances are you need to cleanthe stepper motor and regrease it so the plunger can move in and out freely. Reinstall the stepper motor and see if it's better. If it's not, you may need to adjust the base idle. I thought my stepper motor was bad and bought a new one and still kept on getting code 48 every 5 hours. I checked for vacuum leaks and couldn't find any, but decided to change all of the vacuum hose and 't' body pcv valve. That helped a bit and the code 48 would return every3 days or so. Iwas going to buy a new stepper motor, but decided to readjust the base idle first. After readjusting the base idle, code 48 hasn't return for over1 week now. The truck even idlesbetter than before. If youwant to know how to adjust the base idle, feel free to ask me. Adjusting the base idle isn't hard, but it is a real pain in the butt.
Old May 19, 2007 | 07:39 AM
We don't want people using the new area for questions, that is what this area is for.
Here is a link for your codes.
http://www.fourfold.org/LR_FAQ/RR/FA...ult.Codes.html
Good luck,
Mike
Old May 24, 2007 | 08:52 AM
7th Gear
Update,
After monkeying around a while, I unplugged the MAF sensor. Instantly, it ran nearly perfect. I am guessing that this indicates a bad MAF, unless unplugging it also eliminates something else from the system.
Also, when I removed the idle stepper, the plunger would not move, I assumed this was normal but is it?
Jeff M.
Columbus OH
Cigarhuntr
Aug 2, 2015 05:51 PM
Dodger
Apr 16, 2011 09:54 PM
Henrici
Sep 9, 2010 03:00 AM
n4ujolarry
Jun 12, 2010 07:09 PM
95raingerowver
Feb 19, 2008 07:28 AM
