1995 discovery-- fuel injector problem
Old May 7, 2008 | 11:45 AM
lennie5936's Avatar
Default 1995 discovery-- fuel injector problem
ok, heres what I've found and without a wiring diagram or some help, I'm lost....
My injectors on the drivers side - are showing a 4 volt reading on oneprong and 0 on the other when the vehicle is running. this is the correct reading as I know these injectors are feeding the engine and its running
my injectors on the passenger side - are showing a constant 14 volt reading on both prongs when the engine is running. they are not feeding the engine any gas
I have 2 injector modules and both allow the engine to run but its running on only the 4 drivers side cylinders. and the readings are the same, as to 14 and 4
None of the wires going into the plug for the module appear to have been tampered with although: ther are two heavy gauge wires that appear to have an "inner wire" covered with a copper braded wire. these are taped seperately.
anybody have a wiring diagram that can be sent via e-mail as otherwise I will have to order the manual and wait 3 days and pay 129.00 for it.
i'm on aol.com, so im me and we can talk directly. lennie5936@aol.com thanks
humroot
Nov 30, 2014 12:09 PM
ShadowMerchantBC
Mar 28, 2011 11:43 AM
tornado_735
Mar 31, 2009 09:33 PM
lennie5936
May 16, 2008 06:31 PM
DeepBlueWater
Oct 15, 2007 07:38 PM
