Does anyone know the specs for fuel injector OHMs?
Old Mar 31, 2009 | 04:04 PM
tornado_735's Avatar
Default Does anyone know the specs for fuel injector OHMs?
The mechanic wanted $20 to test it, and I said the hell with it. I took it to Advance and the guy put the meter on it, and it came up as 15.4Ω (ohms). He said it varied, and that he didn't know the specs. He said that is a good number for GM fuel injectors, while Ford injectors are 3Ω. So does anybody know?
Old Mar 31, 2009 | 04:25 PM
I am still doubtful you have an injector issue, you have no injector fault codes and the D2 injectors hold up well.
Old Mar 31, 2009 | 04:33 PM
Oh, but I do. I have posted it at least three times since I have been here. I will post them again, and then I will send them to you in a PM.
Old Mar 31, 2009 | 04:36 PM
P0208 - Injector Circuit Open Cylinder 8 - Code popped up immediately after reset multiple times.
P1300 (and later P1319) - Manufacturer Control Ignition System or Misfire
P0308 - Cylinder 8 Misfire - Immediately/Multiple times after reset.
P0722 - Output Speed Sensor Circuit No Signal (Speedometer and Cruise work fine)
P0300 - Random/Multiple Misfire (Random and Multiple times)
P0305 - Cylinder 5 misfire (Code showed twice on initial scan, but never came back after reset)
P166E - Manufacturer Control Auxiliary Inputs Auxiliary Outputs (showed up again after 4th reset and scan) Not sure what this is.
P1592 - Manufacturer Control Vehicle Speed, Idle Speed Control, Auxiliary inputs (showed up after 4th reset and scan) No problems with regards to this.
Old Mar 31, 2009 | 09:33 PM
roverguy7's Avatar
its good. if those faults keep comming back, you need to check the wiring to the injector... 14.5 ohms +/- .7... its close enough
importdave
Sep 26, 2014 12:06 PM
alanroberts50
Oct 15, 2009 04:12 PM
riggskwong41
Oct 14, 2008 12:24 AM
cst756
Apr 8, 2008 09:48 AM
andrewcloy
Nov 27, 2007 09:15 AM
