1995 transmission help needed
Old Dec 18, 2009 | 01:03 AM
handsome rob's Avatar
Default 1995 transmission help needed
I just put in a used transmission that I picked up from a wrecking yard, has 78K on it and looked in great shape. Put it in and then it started spewing fluid from the input shaft around the torque convertor. I have never seen or heard of this before so I was wondering if anyone had any ideas. It does drive and I did not overfill it so I am stumped.
Thanks for the help.
Old Dec 18, 2009 | 07:01 AM
Long Haul's Avatar
Sounds like the torque converter isnt in properly or your front seal is shot.
Old Dec 18, 2009 | 09:53 AM
When it went in the torque convertor was all the way back in the transmission, it left about a 1/4 inch of space when I went to attach the flex plate, and so it pulled it out from the seal a little. That may be it, allowing it to let fluid through and come out the front.
Maybe I should check that again and see if I can get it back more.
Kyle W. Shore
Feb 13, 2015 08:13 PM
kman3786
Apr 29, 2014 09:18 AM
Snafu / Disco Fries
Apr 1, 2012 07:37 PM
Handy930
May 10, 2008 10:16 AM
geoman
Apr 17, 2007 01:08 AM
