1996 Disco leaking coolant
Old Sep 25, 2006 | 08:02 PM
allstarbiker592's Avatar
Default 1996 Disco leaking coolant
My 1996 Disco has started leaking coolant onto the transmition and all over the driveway. Any Ideas???
Old Sep 25, 2006 | 08:29 PM
geoman's Avatar
Default RE: 1996 Disco leaking coolant
The leak could be from a number of sources. If you see it dripping under the transmission it could be from where the heater hoses pass through the firewall, or from the throttle body heater plate on the underside of the intake plenum. You should also get underneath it with a flashlight and look at the head gaskets behind the exhaust manifolds (on both sides). The coolant could be leaking from the front (i.e.water pump) and blowing back from normal airflow when on the road.
Read my tech sections at www.eurotekapg.com to give you a little primer on problem areas. We are a parts supplier with a strong technical knowledge on all models.
Regards,
Geoman
eurotek apg
Old Sep 25, 2006 | 08:47 PM
Landzu's Avatar
The radiator has a cooler in it for the transmisson the
cooler make have a leak, I would look at that first.
rally1
Feb 22, 2022 06:22 AM
JeffinNC
Apr 9, 2011 02:57 PM
blaze98
Sep 23, 2010 05:49 PM
Vinomack
Mar 4, 2010 06:46 PM
