1996 Misfire, Stumbling, and Knocking
Old Nov 2, 2009 | 09:12 PM
cranky's Avatar
If you are going to take the valve covers off, what do you look for?
I don't think I'd recognise a stuck spring or lifter.
________
How often to charge iolite portable vaporizer
Old Nov 2, 2009 | 09:25 PM
lipadj46's Avatar
Unless it is really bad you may not necessarily be able to see something like that just by removing the valve covers. You would need to remove the rocker shaft and then remove the cylinder heads themselves and rebuild them inspecting each valve individually. What you can see would be sludge deposits or excess varnish build up on the valves. Looking under the rocker covers can give you a general idea of the overall health of your engine as far as deposits go.
Old Nov 2, 2009 | 09:29 PM
After you remove the valve covers start the engine and then go have a look see.
It will only take a min to figure out what is wrong once you can see everything.
Could just be a loose rocker arm nut.
Old Nov 2, 2009 | 09:36 PM
cranky's Avatar
Originally Posted by lipadj46
You probably would not necessarily be able to see something like that just by removing the valve covers. You would need to remove the rocker shaft and then remove the cylinder heads themselves and rebuild them inspecting each valve individually. What you can see would be sludge deposits or excess varnish build up on the valves. Looking under the rocker covers can give you a general idea of the overall health of your engine as far as deposits go.
So not much more than looking in through the oil filler!
I've got a tick and I'm impatient - I've put a cleaner in but it's going to take time.
So I guess taking the covers off isn't going to tell me anything.
________
HARMED BY NEXIUM
Old Nov 2, 2009 | 09:40 PM
cranky's Avatar
won't it **** oil everywhere?
it is on the Left side (your drivers side) so I've got to remove all the air intake?
________
The Legend Condo Cosy Beach
Old Nov 2, 2009 | 09:54 PM
lipadj46's Avatar
To get the rocker covers off the upper IM has to come off.
Old Nov 2, 2009 | 10:20 PM
cranky's Avatar
okay so do I reassemble the upper IM to run it?
Sorrry to be a bit dense!
________
Lolite Vaporizer
Old Nov 2, 2009 | 11:17 PM
Suede's Avatar
Um, he has a '96 DI. All he needs to do to remove the valve covers is remove the four 8mm bolts. It'll take 5 minutes to remove the cover. Start the engine as normal, and look to see if one of the valves doesn't seem to be functioning like all the rest. It'll take less than a minute, and there will be about a table spoon of oil that'll splash about.
If there is oil pooled up at the rear of the head, then the oil channels are clogged.
Old Nov 3, 2009 | 12:46 AM
cranky's Avatar
Sorry Suede,
I sort hijacked the thread a bit, the original poster (tunernewb92) has the '96. I've got a '94. Anyway I would have thought they'ed be the same/similar in the IM size and position.
I've got a similar issue of a tick or knock so I thought I'd chime in - sorry for any confusion.
________
fat girl Cams
Old Nov 3, 2009 | 07:03 PM
On a DI you dont have to remove the intake manifold, you will need to loosen the fuel and heater lines on the right side of the engine to remove that one.
But running a engine with the valve covers off will be alittle messy but not by much.
Back in the old days that is what you had to do to adjust the rocker arms before self adjusting lifters.
You removed the valve cover, started the engine and with it idling you used a feeler gauge and snugged up your rocker arms until they were where they were supposed to be.
