1999 Discovery II lost key replacement
Old Nov 3, 2024 | 05:56 PM
altereel_vil05's Avatar
New Member
Default 1999 Discovery II lost key replacement
I recently lost the only key for my 1999 Discovery II. Do the keys have an immobilizer chip that need programming? Im wondering if I can just go to a locksmith and get a metal key cut out.
Old Nov 3, 2024 | 09:02 PM
PickleRick's Avatar
No chip on the key, just keyless entry.
Old Nov 3, 2024 | 11:25 PM
mollusc's Avatar
Plain metal key will work just fine. I never had a fob for my '99. However, you should replace the lock pin inside the driver's door if you're going to rely on that as your only means of access to the vehicle. Carrs4x4 sell an upgraded version, and you can find several discussion threads on this forum detailing the reasons why this is something to do sooner rather than later.
Old Nov 4, 2024 | 09:53 AM
Harvlr's Avatar
If you get a used fob you can program it to your BCU with a Nanocom.
Old Nov 4, 2024 | 12:38 PM
AjjayS's Avatar
I might be dumb here, but if you lost the only key, then how would you get another one cut? Or can a locksmith cut one from the VIN?
Old Nov 4, 2024 | 05:25 PM
Harvlr's Avatar
On older cars with more basic keys, a good locksmith could cut one using the ignition barrel. I think it’s a lot more difficult with these keys.
Old Nov 5, 2024 | 09:21 AM
PickleRick's Avatar
I cut keys here at the shop. I can verify 100% it's easier to cut older one sided keys vs the Rover double sided key. My key cutter is the old school hardware store manual machine. I've botched more double sided keys than I've succeeded. Luckily there's enough play in the old disco 2 barrels and my old yota that I don't need them perfect. As for the common door/deadbolt and master lock keys, I have zero issues getting those right 99.9% of the time.
For programming the disco 2 key fob I use a cheap 79 dollar Chinese obd2 two way blue tooth dondle
redrover75
Feb 23, 2022 11:15 PM
Atlrover89
Sep 7, 2018 10:04 AM
ko7651
Nov 6, 2016 09:20 AM
Strikker
Oct 8, 2015 09:19 PM
shltn
Oct 2, 2013 11:11 AM
