Things to do with the headliner out
Old Oct 28, 2024 | 11:44 AM
cappedup's Avatar
Default Things to do with the headliner out - DONE (pics)
Removing the headliner isn't difficult. Lots of steps, already covered here and YT. I found all my plastic bits very strong, nothing snapping out of character.
Nice to see my sunroof drain fix from years ago is still holding fine. https://landroverforums.com/forum/di...=Sunroof+drain
I’d like to solve the issue of water through the seatbelt, after rain.
I was thinking just fit rear sunroof drain pan drains. But looking at it, the pan is about level, when I look at it where I usually park the car. I’m not sure the pan is filling up because of the angle.
Plus, how would that water then get out of the pan, it all looks pretty sealed with the pan screwed to the top.
Looking at the back of my headliner, water has clearly been sitting, at the rear and possibly the front. (I’m also getting water into the trunk after settling off from parked.)
Whats the latest best guess for water thought the drivers seatbelt??
Also, I think I’d like to insulate the roof a bit, dynomat because it’s easy. Are there any accepted fibreglass (or similar) panels to use up there? Be nice to cut the noise from the rack.
Old Oct 28, 2024 | 05:23 PM
cappedup's Avatar
Found an issue with the rear drain pan.
Sun visor clip holes. Making me think the drains are blocked if the water is backing up to there.
Taking both pans out tomorrow.
My suspicion with the front leaking out of the seatbelt now is that the sun visor clip holes were letting water sit on top of the headliner, as it’s waterproof. Then as I set off driving it finds its way out of the seatbelt.
Fitting rear drains to both pans and checking all drains are clear.
2nd time I’m here. Don’t want a third.
(especially after I get the new material fitted)
File Type: mov
Old Oct 28, 2024 | 08:51 PM
Extinct's Avatar
I thought I did a thread on this somewhere, maybe a search? Put rear drains in. Tee in to the front drains and tee the front pan drains in to the rear so everything can either drain forward or rear, left or right. Seal every crack in the pan, sunshade clips, screws, and factory drain corners. Take the roof bars off and silicone seal the penetrations. Pretty sure I showed how to seal the motor gap in one of my previous post on this topic. Drive it for 2-3 months with the headliner board out to find every last leak. Paint the top of the board with low odor stainblocking kilz paint to prevent soaking the board and fabric. The headliner board is shaped to direct any water on top of the board to the seat belts to drain out of the roof, that is the design. I have a pattern cut for radiant barrier liner to go between the board and the roof and install videos to go with it, just have not had time to turn it in to a product on the website yet purchase. Takes about 15 mins to install, will take you a full day to cut via trial and error. I keep a roll of material here.
Old Oct 29, 2024 | 08:39 AM
CharminULTRA's Avatar
Sunroof to body seals - It’s a fairly involved job, I'd recommend 2 people, but it’s important to completely remove the sunroofs and clean and re-seal the sunroof frame to the body. The seals deteriorate (just like this entire car) and any work you do elsewhere will be in vain without these.
The most common fix is a permanent Permatex silicone here. Since it’s permanent, make sure you do any other procedures first.
Old Oct 29, 2024 | 08:41 AM
OP, Extinct’s post to follow is this one 🙂
https://landroverforums.com/forum/di...81/#post713877
Old Oct 29, 2024 | 11:32 AM
nashvegas's Avatar
In addition to all of the sunroof sealing, undo all 4 of your bolts holding the roof "rails" on, and put a dab of black sealant on the foam seals (sikaflex or similar on the mounting locations (just a bit) then resnug them down. These do leak on many trucks. Problem is, when they do leak, they leak between the inner and outer roof shells, and you never know it ... until it is too late. Easy to do with headliner out. Simple nut on each accessible from below when headliner is out.
And what Charmin ultra says - he is talking about on the top of the car, the exterior. The black plastic frame on the EXTERIOR to the top of the car.. ou must remove the metal frame on the interior, lower that contraption down inside the car, then the black plastic frame lifts off and UP on the outside ... then you put the sealant on that black plastic on the exterior and put It back down on the roof of the car.
Old Oct 29, 2024 | 11:42 AM
cappedup's Avatar
I like the idea of tee-ing between the front and back of the pans.
I found some nice fittings to do this with, and using clear hose so I can see where water is running.
Front pan is in progress now.
Ordered some silver barrier, and some sticky hush mat. Hoping to reduce noise from the rack a bit. (I’d buy your kit if you had it ready.)
These headliner boards really do hold up well to wet. You can see where water has pooled in mine for years.
On the plus side, the old foam is coming off really easily with a regular stiff brush.
Thanks.
Old Nov 5, 2024 | 10:17 AM
cappedup's Avatar
Default Finished
Done.
Tee’d between the front and back of the pans.
Used these fittings from HD. https://www.homedepot.com/p/SharkBit...8A10/318224300 With some 2 mix epoxy putty designed for wet use. Did an overnight test and it is strong af. Then some tubing to fit.
I could see where water was coming from the rear sun visor holes. Easy plug. The pan was filling up because the outer seal (sunroof to body) had failed. I park on a slight incline, so water was sitting at the back of the pan, filling til it leaked out of the clip hole.
Pulled the whole sunroof from the rear (I’d done the front a few years ago), and sealed it back in with this stuff. https://www.homedepot.com/p/Loctite-...5273/319655237
Hasn’t rained here in about 3 months, so had to test with a hose for a few hours. Parked in different spots. Did the best I could over a few days. Not a drop inside.
Headliner isnt as easy as I hoped. I wish I had a second attempt at it. The biggest tip I can give, is pay attention to the areas you will be looking at for the next 10 years, because I now have a wrinkle, right where I will always see it.
That said, it isnt a nightmare. I used 3M headliner glue. It’s a bit more forgiving than 3M 90. ‘Slightly’ repositionable, maybe twice.
The headliner came from here, 3 yards. https://www.albrightssupply.com/extr...-67-weh2300xxw
I stuck vibration damping material on the exposed panels. This stuff - https://a.co/d/01kD9k3
Then reflective insulation/barrier - https://a.co/d/4fnlrno
Reassembly is pleasurable. Nothing broke. I can see how people break the visor clips. I slightly shaved the edges of the bit that goes through the body with a knife, so they didnt take so much stress. I’m hoping I’m now leak free for the rest of this cars life.
The biggest day to day win is the insulation. OMG it really shows a LACK of insulation from the factory. The roof rack noise is masked by about 50%, but the real win is the thermal performance. Driving with the heater on is now comfortable, instead of odd temperature gradients in the car. Before the top of my head would be cold, but the middle of the car would oddly be too hot. Cold feet.. etc. Now its a much more even temp through the whole car.
Ive got tons of the material left, I’ll be adding more of it, whenever I’m inside a panel for some reason.
Heres a bunch of pics. Any questions, fire away. Job time was about 3 days on and off. Longer than I wanted, but I didn’t take any shortcuts. I don't want to go back there again.
PilotHobs
Mar 12, 2023 09:47 PM
losinov
Aug 20, 2022 03:41 AM
lndrover@carolina.rr.com
Jan 17, 2020 11:20 AM
Dec 31, 2019 07:52 AM
jdill732
Apr 2, 2011 08:57 PM
