1999 V8 body roll....
Old Mar 3, 2013 | 07:18 AM
gorry's Avatar
8th Gear
Default 1999 V8 body roll....
Hi, new on here. Just bought my Disco over here in NZ. Seems a good car only done 160k kms, which is nothing for a car over here. Seen plenty of cars with 300ks driving about.
My problem is she has terrible body roll whilst driving, not just cornering, going in a straight line is bad. Seems Luke the suspension is set in jelly. Having to constantly make minor adjustments to the steering. Looked underneath, everything seems ok and tight. Recently had extra heavy-duty springs fitted and tyres are as new, only a few months old. These two items were fitted prior to me owning the vehicle. If I stand outside and push the body she seems very soft and loose on the suspension. Could this be the front panhard rod bushes ? Seems ok when I get under there and give it a tug...
Any help would be greatly appreciated.
Thanks.
Old Mar 3, 2013 | 07:24 AM
iambhooper's Avatar
The shock s could be worn out. The ones on mine were shot. I replaced them and my truck runs much better. I used the kyb shocks.
Old Mar 3, 2013 | 08:35 AM
jafir's Avatar
Does it make noise? Perhaps watts link bushings in the back? Maybe the previous owner removed the anti-sway bars when fitting the HD springs?
Old Mar 3, 2013 | 08:41 AM
coors's Avatar
Thanks.
A few items to inspect. Look at the steering bars (tie rod ends) there are four total. See image below. I just ordered a Terrafirma set from Lucky8 to replace my stock/original bars. I have play in the joint that connects to the pitman arm and I'm sure there is play in the track rod ends . My truck wonders whilst driving down the road.
Another item to inspect is located in the rear, the watts linkage. See image below.
Old Mar 3, 2013 | 08:48 AM
Bad shocks.
Old Mar 3, 2013 | 10:55 AM
gorry's Avatar
8th Gear
No noise, slight clunk on acceleration which I guess is a bit of play in a uj ? Dark at the mo, can't get under the car at the minute to check the items mentioned. However, don't recall seeing those rear anti sway bars when I last looked. Surely the guy wouldn't have removed them ????
Old Mar 3, 2013 | 11:13 AM
wreckdiver1321's Avatar
It's entirely possible that someone did, especially if it was used as an off road truck. But then, many people take them off, drive them on the road for a day, get scared, and put them back on. So I'd still think shoddy shocks are the most likely.
And as for that clunk... It's a Rover thing. Mine does it too, and all my u-joints are in good shape.
Old Mar 3, 2013 | 12:52 PM
gorry's Avatar
8th Gear
Old Mar 3, 2013 | 12:56 PM
gorry's Avatar
8th Gear
Don't know why the above posted again...
Just checked, no sway bars. Just anti roll bar. No sign that it ever had those bars in photo fitted. It's a 1999 imported from Japan, could it be a different model ? Possibly without those bars ? No mounts or fittings for them.
Old Mar 3, 2013 | 01:32 PM
So you do have anti roll bars? That's what they're meaning by sway or anti-sway bars. Just another way of saying anti-roll bars.
Wait. Do you have a Discovery I or Discovery II? Because, if memory serves me correctly, the Discovery I didn't have a watt's linkage like the DII had. The watt's linkage is pictured above.
