2" or 3", 32" or 33" tire
Hey guys,
I'm planning a trip to Moab with a family member in their Jeep. I'm gonna take on some pretty tough tracks (Hell's Revenge and other tracks rated as sixes). I currently have 32" tires on my car and a 2" OME lift. I'm going to replace the springs with HD versions, and want to ask if you guys did it again, would you go with a 2" lift or the OME 3" lift? I suppose the advantage to the 3" lift is I can fit 33" tires. Is this worth it? Does the extra inch make a big difference? It definitely looks better. I may hang onto my 32" tires (265/75r16) for a bit, would that look odd on such a large lift? I've also heard mentions of goodies from RTE for extra articulation, any recommendations? Should I just bite the bullet and buy one of those expensive RTE lift kits and big tires?
Thanks,
Jacob
Thanks,
Jacob
Hey guys,
Thanks,
Jacob
Thanks,
Jacob
Word of caution about going with HD spring rates. I went HD and should have gone medium. If you don’t spend the majority of the time with several hundred pounds of gear the HD springs ride very rough.
jacobmstein (12-09-2020)
Having been to moab on both 265 and 285s I wouldn't worry too much unless you plan on tackling something harder than hells revenge (ie moab rim). If you have a good rear bumper you'll be fine as the *** end likes to drag off everything out there. Also, almost everything out there has a bypass or large variations in line options if it's truly a big obstacle.
I'd run 3" RTE springs, extend the brake lines and abs lines, disconnect the sway bars and either tire size will look great. 285s on the alloys may not need trimming but I needed to trim running the steelies and my suspension was toast when I got them which didn't help the issue.
Also, I'm going in 5 months, so I have time to put some money aside. Is it worth locking the rear (and eventually the front)? I don't like the speed I have to take some obstacles when my wheels lift. I should probably get a CDL linkage from a D1 first as my truck is MY2000.
My OME set up came with my truck and was pretty tired (drove/wheeled the crap out of it for 2 years still) and didn't have a lot of complaints other than it was very much not 3" of lift anymore. I've been pleased with my RTE springs. First few trips I only had a CDL and it did just fine. I have a locker in the rear now and it just makes things a little easier. However, I go in Feb usually so there is some snow or ice so the locker really helps on say Top of the World (trail is bunch of shelfs/ledge and bumpy as hell) but it's at a higher elevation and a little outside of town. The rock out there is insanely grippy so a CDL and working TC you won't have any issues. I would remove the sway bars once you get to town if you are driving it out there. You have to extend the brake lines and abs lines if you do this on a 3" lift! I would remove the sway bars at least once before you go as mine have always been a nightmare when doing suspension work (had to cut them out of my white one..). Or you can move your front links to the rear and get LR3 links in the front and that will free up a ton of articulation and still keep the road manners.
Sure have. Stock LR3s have done it. It’s not that hard but line choice is paramount. One in our group took a little dirt nap with a poor line choice way before the crux.
someone makes some disconnects I think L8 has them? For the money I’d try the LR3 front links and see how it does. That’s my plan for my wife’s disco just haven’t gotten around to it yet.
edit: can’t get video to upload but I have a video up on my Instagram: whowa004
