2" or 3", 32" or 33" tire
#21
#22
The issue I had is Rovers North sold me OME MD springs as suitable for a steel bumper AND winch, which they certainly are not. That's 250 lbs of extra weight. The front is sagging maybe an inch, I'm not very happy with it. That said, you'd still go with spacers? My issue is the bumper is so low I need all the clearance I can get. I bought a winch on black Friday but have yet to fit it since I bet it'll drop another 0.5-1".
jacobmstein (12-10-2020)
#23
#25
#26
Thanks,
Jacob
#27
jacobmstein (12-19-2020)
#28
Thanks. Simon told me it would be potentially dangerous since the steering geometry wouldn't be correct, I don't think he tried to pressure me at all, I just think he wanted to warn me. I'll probably go for what he recommended when I get the $ for it, but good to know I can just run the springs. I assume I can just use my OME shocks also.
#29
Anytime you lift something the geometry is going to change (even with just a 1inch spacer vs stock) however I drive 80MPH in m D2's and I find the steering to be fine. Only time I ever had crappy steering is when I blew out the OEM tie rods after a weekend of off roading thru boulders. Replaced them and my steering was back to normal. I personally think 3inches of lift on a D2 = the sweet spot.
#30
Castor def needs to be corrected and the radius arms from Simon are super beefy. However I think unless you are wheeling it super hard the full arms are a little overkill. Can get castor correcting bushings from the UK or Oz or make castor corrected plates as I think a member here had just done maybe a month or two ago which was clever.
jacobmstein (12-22-2020)
