2 of the 3 amigo's
Old Jan 28, 2012 | 02:11 PM
gotmud's Avatar
Default 2 of the 3 amigo's
hey guys i have 2000 disco 2 and i had the 3 amigo's on so i did the abs mod and they were gone then i had to change the engine in it and now just the TC and HD lights are on not the abs light and the abs is still working on it just fine any thoughts would be great thanx
Old Jan 29, 2012 | 09:30 AM
Have you tried the HD to see if it is working, if it isn't you need to get the system scanned for fault codes.
Let us know what you find.
Old Jan 29, 2012 | 10:22 AM
gotmud's Avatar
i had it scaned but the only code was in the slabs and it was signal fail from ECU so i changed it but the lights are still on and the TC and HD do not work
Old Jan 30, 2012 | 08:21 PM
gotmud's Avatar
anyone have any ideals
Old Jan 31, 2012 | 05:52 AM
tee51397's Avatar
I'd check wiring and the throttle position sensor. You have those two on because of a bad link or faulty data between the SLABS and Motronic ECM- either real or perceived by the software. Since you've swapped out the SLABS you know it lies somewhere else.
Start with the TPS and then let us know.
Old Feb 1, 2012 | 07:47 AM
gotmud's Avatar
ok changed the TPS and did not change anything scaned it again and still says signal lost from ECU thats what it said befor i changed the ecu would it posibly be a bad ground wire ???
Old Feb 1, 2012 | 10:22 AM
Stop throwing parts at it. Send me your number and I'll call you and walk you thru what to check/do.
Old Feb 1, 2012 | 07:32 PM
gotmud's Avatar
pm sent thanx
Old Feb 2, 2012 | 04:43 PM
gotmud's Avatar
ok changed the abs computer did nothing lol man i hate stupid lights
Princess
Jul 4, 2009 12:24 PM
Dino76
Feb 12, 2008 03:03 PM
Kraftyz51
Aug 23, 2007 09:18 AM
lrblack12
Aug 22, 2007 02:35 PM
