#2 Engine Management System fuse keeps blowing..
Old Dec 23, 2017 | 06:45 AM
mollusc's Avatar
The D2 Electrical Library says that it's the fuel pump, cooling fan, and the signal from the main fusebox to the ECM.
Old Jan 2, 2018 | 02:29 PM
cobbcj7's Avatar
plugging in the Inertia switch causes the #2 fuse to blow.. but also, when I jump the plug to the inertia switch blows the fuse as well.. so it's not the switch, its in the wiring...
Old Jan 2, 2018 | 03:22 PM
mollusc's Avatar
Seems like that should be a relatively simple replacement. The switch is probably shorting to ground internally.
Old Jan 2, 2018 | 04:16 PM
cobbcj7's Avatar
updated my comment.. its not the switch itself
Old Jan 2, 2018 | 04:20 PM
cobbcj7's Avatar
unplugged the leak detector and didn't help.. tested the wires to the leak detector.. no resistance/not grounded.
The only issue I have found so far is that the C0635 plug to the ECM PIN#13 White/Orange wire is a dead ground. #1/7/19 have continuity but 13 is dead. That is the RH-up stream O2 sensor..
I tried cutting that wire (didnt change anything) to isolate that circuit and also disconnected that O2 wire.. Nothing changed.
With the inertia switch unplugged nothing blows so I would assumed that the O2 sensors are not the issue.
I am running out of wires to test and ideas.
Old Jan 11, 2018 | 10:27 PM
cobbcj7's Avatar
Default Update
I went by a junkyard today that has plenty of the ECM's on hand. I grabed one and just to test, pluged it all in. As soon as I turned the ingition to the on position, the fuse blew again...
So It's not my ECM.. It must be between the inertia switch and the ECM..
Old Jan 12, 2018 | 07:22 AM
dgi 07's Avatar
may come across as a stupid question, but when you do your resistance test on your wiring, what readings are you getting?
0.2 ohms? 0 ohms? O.L. ?
Old Jan 16, 2018 | 01:22 PM
cobbcj7's Avatar
The resistance on the wires to and from the inertia switch are 0.001 ohms.. And when we reset the switch, the wires show 0.237 ohms....
With the inertia switch unplugged, the #2 fuse will not blow. When we plug it in, or if we jump the wires on the pigtail to the switch, the fuse pops..
Old Jan 17, 2018 | 01:17 PM
dgi 07's Avatar
Figured i would ask just to clarify.
I would personally go after wiring. I don't think its the switch. I think is a wiring issue somewhere. Maybe the connector is shorted together, or a wiring is grounding out.
Hard to tell over the interwebz though.
Old Jul 3, 2019 | 09:32 PM
Jlc's Avatar
Jlc
Default Discovery fuse issue
Did you ever found the issue for the engine managent system relay #2?
I have the same trouble and Im going crazy alredy
