2" lift block bolt size
Thanks for the reply. I should have said that those are not the actual blocks I bought. Mine are a true 2" so 50mm bolts won't even protrude. I just haven't looked to see what I'm clamping them between to understand how much additional bolt length I'll need. Sounds like I'll need at least 65mm.
I removed front lower shock bolt and added spacer height, ran to parts store, bought 8 new bolts, grade 8. Got home, finished front, all good. Started on rear and new rear bolts were a tad to long, shoulder of bolt prohibited usage...could have added a few flat washers...but decided against it and made a second trip to parts store...hurray. l believe the rears were about a 1/4 inch shorter...and still added one extra flat washer.
Sunny side auto
04-02-2011 06:28 PM
