Sponsored by: CARiD
How much $ to lift disco 3 inches
Old Apr 30, 2014 | 11:55 PM
moglide's Avatar
Default How much $ to lift disco 3 inches
Is it any harder to lift disco than jeep or typical American truck.Would like to do myself and are kits more expensive.What size tires can you use with 3 inch lift,what inch bolt pattern on discovery,thanks
Old May 1, 2014 | 12:11 AM
abran's Avatar
Disco 1 or 2?
2" lift, $900, 1" body lift... Apparently the cost of hockey pucks and bolts.
Good luck.
Old May 1, 2014 | 12:22 AM
moglide's Avatar
disco 1
Old May 1, 2014 | 12:58 AM
abran's Avatar
Same as I noted above. It's not hard. You can go up to 32"/33" with a 3" lift. You might need to do some customization of you front bumper end caps.
Old May 1, 2014 | 06:58 AM
Paul Grant's Avatar
More importantly, anything over 2" starts to bring driveshaft angle and camber issues into play.
Old May 1, 2014 | 07:53 AM
moglide's Avatar
Don't want to get into drive shaft issues,I'm guessing brake lines may be a problem too.How much to do a 2 inch lift,maybe just switch out coils.
Old May 1, 2014 | 08:06 AM
abran's Avatar
If you do the couls you should do the shocks as well. OME kit at Atlantic Britsh is 800+. If you just do coils you might need to adjust your shock mounting points(shorter front shock towers and longer shock mounts in the rear).
Old May 3, 2014 | 06:20 AM
Paul Grant's Avatar
Bolt pattern is 5 x 6.5. Not at lot of wheel alternatives. If you do a 2" lift you can run 245/75/16 without needed to do any trimming (rear especially). I know that's not a very big tire but you'd be surprised how far you can get with a 2" lift in these trucks.
Old May 8, 2014 | 06:45 PM
socal1200r's Avatar
Doing a 2" lift with coil springs and longer shocks is on my "to do" list. I'm also planning on changing the wheels to something like 15x8 Pro Comp steel wagon wheels, so I can run 31x10.50s.
So if I stay with 2", there shouldn't be any brake line, driveline angle, or rubbing issues with 31x10.50s?
Old May 9, 2014 | 09:17 PM
Inches of lift = inches of stack of money.
