2" old man emu question
i did a 2,5 arb old man emu nitro charged and heavy spring ,bushing ,noting elese need execpt a good spring compresion tool and time it take about a full saturday of work alone
i drop 245/75R16 michelin ltx at2
aligment is good to
after the lift done your truck will never be the same
aligment is good to
it always in a good way you changed stuff mine from arb i think was good bang for the buck and i really like the truck run on the road since i did it i only run on snow but i feel the difference especialy when i pull my 24 foot trailler to carry other toys i hope soon when taw overhere was finish i will try it on a trail i let you know how i like the truck at this time
(if i remember its a land rover that we talk so it mind that you have a very extra long travel before wheel are off the ground if you lift from the truck frame )
so if you are using the same technic that i used (floor jack and arm ) i just cant figure how to changed spring and shock whitout a spring compresion tool
i was actually thinking about that little problem. i was thinking put the jack on the ramp to get an additional 6"s or so, my jack stands go high enough so the time on jack/ramp combo would be only long enough to get her up in the air.
ps, curious, what is the stock travel on stock coil all around 00 disco?
I think I heard 18" shock travel stock....that's just what I've heard.
FWIW, even the 3" TF springs go on without a spring compressor or removing sway bars or disconnecting the brake/ABS lines...in the back it was pretty tight, but that was more the brake lines than anything else...overall it's not difficult, just time consuming.
I'd imagine the 2" OME springs should slide in without much trouble...
tjhappel
02-19-2011 12:47 AM
mikemeyer0
03-30-2005 06:17 PM
