2" old man emu question
Old Mar 20, 2011 | 01:12 AM
handsome rob's Avatar
It is not required but it is nice to get an alignment after the lift. Other than that I cannot think of anything else you will need.
Old Mar 20, 2011 | 09:09 AM
charlotte007's Avatar
7th Gear
i did a 2,5 arb old man emu nitro charged and heavy spring ,bushing ,noting elese need execpt a good spring compresion tool and time it take about a full saturday of work alone
i drop 245/75R16 michelin ltx at2
aligment is good to
after the lift done your truck will never be the same
Old Mar 20, 2011 | 03:19 PM
grandkodiak's Avatar
in a good way or bad?
Old Mar 20, 2011 | 03:20 PM
yloDiscoII's Avatar
aligment is good to
FYI : You DO NOT need a spring compressor to do this job. There are really no "extra" tools required. A good ratchet and wrench set and you're good to go.
Old Mar 20, 2011 | 06:34 PM
7th Gear
it always in a good way you changed stuff mine from arb i think was good bang for the buck and i really like the truck run on the road since i did it i only run on snow but i feel the difference especialy when i pull my 24 foot trailler to carry other toys i hope soon when taw overhere was finish i will try it on a trail i let you know how i like the truck at this time
Old Mar 20, 2011 | 06:42 PM
7th Gear
yep but my floor jack did not lift all the way up to the sky
(if i remember its a land rover that we talk so it mind that you have a very extra long travel before wheel are off the ground if you lift from the truck frame )
so if you are using the same technic that i used (floor jack and arm ) i just cant figure how to changed spring and shock whitout a spring compresion tool
Old Mar 20, 2011 | 06:54 PM
i was actually thinking about that little problem. i was thinking put the jack on the ramp to get an additional 6"s or so, my jack stands go high enough so the time on jack/ramp combo would be only long enough to get her up in the air.
ps, curious, what is the stock travel on stock coil all around 00 disco?
Old Mar 25, 2011 | 12:09 AM
yloDiscoII's Avatar
Just get creative where you place the bottle jack in between the frame and the axle after you get the truck high enough, no spring compressor and didn't remove the rear sway bars and did it all by my lonesome.
I think I heard 18" shock travel stock....that's just what I've heard.
Old Mar 25, 2011 | 08:07 AM
dcarr1971's Avatar
Just get creative where you place the bottle jack in between the frame and the axle after you get the truck high enough, no spring compressor and didn't remove the rear sway bars and did it all by my lonesome...
x2
FWIW, even the 3" TF springs go on without a spring compressor or removing sway bars or disconnecting the brake/ABS lines...in the back it was pretty tight, but that was more the brake lines than anything else...overall it's not difficult, just time consuming.
I'd imagine the 2" OME springs should slide in without much trouble...
James Vee
Jun 16, 2016 09:00 PM
BCDisco2Lando
Apr 9, 2015 08:14 AM
aarongregor
Oct 11, 2012 04:02 PM
tjhappel
Feb 19, 2011 12:47 AM
mikemeyer0
Mar 30, 2005 06:17 PM
