2-Part Question: Squealing noise coming from automatic locks and turn signal bulb???
I own a 2002 Disco Westminister:
Hey guys, I know that my title sounds a little wierd, but I just had to replace my rear driver's side turn signal bulb (the amber lens on the bumper). I was first alerted to this when the left side blinker went into hyper-mode and was blinking doubletime... so I checked the bulb and sure enough it was burnt out. I found the a replacement bulb at NAPA. Installed the bulb and things are working great, problem solved right? Well, I am curious to know how serious or important it is to use the exact OEM or spec bulb. The left side is now slightly brighter than the right. This could be due to the left side being a brand new bulb...
Second: there is a funny squeal coming from, what seams to be the automatic locks. I first noticed the noise when I was testing the old and new bulbs when investigating the blinker issue. Is there a solenoid that can fail here? I used to drive a VW Passat with automatic locks and a solenoid went out and the trunk wouldn't unlock. Could this happen with the Disco? What could be making this funny squeal noise? You only hear the noise when you push the Lock button on the key, still locks just fine, but this noise just started and wondering if it might get worse.
THANK YOU FOR YOUR EXPERIENCE AND HELP WITH THIS! I AM GLAD TO BE A PART OF THE LAND ROVER COMMUNITY!!
Save yourself some time, and just buy all the bulbs you need, replace them all at one time (because once one goes, it's probably about time the rest will as well), and everything will be evenly lit. Or don't. It will still be fine.
If it is only on locking/unlocking, you start by taking off the trim and lubricating the mechanism. Test it while open. If it's not that......you've pretty well narrowed it down.
jimmyvietvu
Jun 23, 2013 07:12 PM
