2 Years of no troubles
Old May 26, 2016 | 12:59 PM
Big Jim Swade's Avatar
Default 2 Years of no troubles
Granted, I don't drive my 01 Disco that much and it only has 71k miles on it, but I haven't had any troubles with it since Memorial Weekend 2014. The water pump was leaking so I changed it on that weekend. Other than one oil change and I installed a CDL lever from an 04 in it, I haven't had to turn a wrench on it for 2 years.
Old May 26, 2016 | 02:03 PM
zuke's Avatar
Default Bad Joo Joo
Oh man. You just jinxed it.
Expect a slipped sleeve any day now.
Old May 26, 2016 | 02:10 PM
NickAdams's Avatar
Boy oh boy! You just put the hex on yourself big time. Keep us posted on how the head gasket, power steering pump rebuild, new O2 sensors and abs pump jobs go.
Old May 26, 2016 | 02:40 PM
I hope I didn't jinxed myself also.
Old May 26, 2016 | 09:02 PM
Frank4's Avatar
X2.
I don't even want to say what I think is wrong with mine out loud for fear of the Land Rover gods casting vengeance. The OP is a brave man indeed. Godspeed sir and may your check balance have many commas and zeros.
Old May 26, 2016 | 10:41 PM
Alex_M's Avatar
Last time I said I hadn't had any problems in 13k miles (about a year), my ckp went out immediately after I spent two days putting together a new exhaust system. Then I broke the harness end clip replacing it. Then I spent three days outside in 30 degree weather and snow working on it trying to get it fixed. Never again.
Old May 27, 2016 | 02:41 PM
DiscoBuckeye's Avatar
Too late!
Old May 29, 2016 | 11:21 AM
Shiftonthefly1's Avatar
You're screwed.
Old May 29, 2016 | 08:52 PM
jamieb's Avatar
"So then what's the point in owning a truck? What purpose would it serve if people just bought trucks and all they did was drive them? Owning a truck should be 93% attention to them mechanically and 7% recreational use. "
As quoted by Mr. Landy A. Rover
Old May 29, 2016 | 10:44 PM
Charlie_V's Avatar
Your jinx even extends to my rover. THANKS!
