20 min job turns into new repairs
Went to install the new group 31 bigger battery. Battery fit in the tray like a glove was messing around with the negative wiring and pushed down on the ****ty plastic tube from rad. Broke right off
ok no problem good time for some 5/16 rubber tubing from rad right ?
went to take the rest of the plastic tubing out noticed top of rad a bit wet lol push down on it well we’ll well a bit of green stuff
so new battery Turns into another fed hundred bucks for rad tubing etc
well at least it didn’t blow on the road
One issue with using rubber hose, it doesn't fit properly into grooves on top of each end of radiator shroud. If forced into groove, it collapses hose, restricting return flow to reservior. I like using copper tubing, easy to bend, fits in groove and is much more durable than plastic or rubber.
And yes, if you can make a repair, without causing another...it's always a good day.
One issue with using rubber hose, it doesn't fit properly into grooves on top of each end of radiator shroud. If forced into groove, it collapses hose, restricting return flow to reservior. I like using copper tubing, easy to bend, fits if groove and is much more durable than plastic or rubber.
ya I hear you on my old d2 I had that issue of the hose being too thick
I was thinking of using the copper actually. I have the 1/4,refrigeration stuff I think somewhere It’s thicker stuff over the water stuff
You could instead use just a short section of hose and a couple small hose clamps to splice the nylon hose that broke.
It's interesting to me that so many here have trouble with the nylon lines. I removed the one from the TBH to the expansion tank after I bypassed the TBH and I can literally tie it in an overhand knot without it breaking. It's the same kind of black nylon material used for the ugly "unbreakable" glasses I wore for high school sports.
Brandon318
08-25-2023 11:18 AM
