2000 4.0L V8 origin
RE: 2000 4.0L V8 origin
Actually they started out as a Buick 215 CID (3.5L) so I think they're bored and stroked, not reduced in displacement. See Wikipedia:
http://en.wikipedia.org/wiki/Rover_V8
http://en.wikipedia.org/wiki/Buick_V...small-block.22 <--Scroll down to "215"
Yeah Rover used the engine for a total of 40 years in one form or another I think I read.
Mike, so if it's just stroked, then does this mean the 3.9 heads from my 95 Disco will just bolt on to a 4.6 short block? (plug & play fashion?) What I'm getting at could I drop in a 4.6 rover shortblock in place of my 3.9 block and keep the same intake & ECU etc? Do you think there would be any significanthp/torquegains from this? Do the 4.6 heads have bigger valves?
I read where a guy replaced his 4.0 with a 4.6. I think the only thing he had to change was going to a D2 knock sensor fo clearance. It still had the 4.0 heads, intake and ECU. I'll see if I can find it again.
got it.... http://home.twcny.rr.com/eeibooks/rover/engine.htm
on
ORIGINAL: mordor110
Mike, so if it's just stroked, then does this mean the 3.9 heads from my 95 Disco will just bolt on to a 4.6 short block? (plug & play fashion?) What I'm getting at could I drop in a 4.6 rover short block in place of my 3.9 block and keep the same intake & ECU etc? Do you think there would be any significant hp/torque gains from this? Do the 4.6 heads have bigger valves?
Mike
ORIGINAL: okdiscoguy
