2000 Disco A/C & other stuff
Old Aug 2, 2007 | 10:03 AM
mcneal's Avatar
Default 2000 Disco A/C & other stuff
I have a 2000 DiscoII with 115k. i am getting random misfire and system too lean codes so the CEL is on. From what ive read i need to replace all the O2 senors, so i waiting on the $$ to do that. I alsoget the three amigos on a regular basis but they go out after five minutes with the truck off. needless to say ive got a few problems. My A/C blows cold seems to work well, the passengers side ita little warmer but not by much. I bought gagues to read the high an low pressures, both were in range. However, when the A/C is on the truck runs poorly, just seems like its working too hard, almost stumbling/missing. When i am on the the interstate i will use the A/C but not around town, if i turn the A/C off it purrs like a kitten. Any ideas? Is this normal or a symtom of my other problems?
also about the three amigos... my brakes seem to be wearing uneven. the front drivers side get dusty much faster. and it seems like idont always have ABS, its itermittant. Are these tell tale signs for the a bad ABS modulator? or should i just bleed the lines?
any advice would be appreciated, thanks in advance!
Old Aug 2, 2007 | 12:12 PM
Default RE: 2000 Disco A/C & other stuff
What are the exact fault codes you are getting?
Lots of question, you might want to call me or send me your number and I would be glad to walk you thru your trucks issues.
Mike
303-862-7680
Old Aug 2, 2007 | 12:39 PM
mcneal's Avatar
when would be a good time to call im in S.C. and work till 5, would after work be ok? I know theres a time difference to consider.
Wolfs disco 1
Mar 7, 2014 12:35 PM
Wolfs disco 1
Mar 7, 2014 12:24 PM
cer308
May 10, 2012 04:14 PM
vinvelasco
Aug 19, 2008 12:16 AM
OlDood
Jul 4, 2007 10:23 AM
