2000 disco: front abs code. output low?
Hi there guy's!!!! I'm working right now on a 2000 discovery, I found more than 16 abs codes.... One of then was the shutle valve. Wich i did replace with a new one and also did the by-pass. clear all those codes and I' m just getting the front right and left abs out-put low.... OK i did order the new sensors and install them today and still getting this sucker codes.. I did check every ground in the engine bay and inside the cabin by the brake pedals "top left"..... Also unplug every single plug to the abs computer and clean it with a small screw driver and plug it back in place.... If i clear the codes they come back in about a mile drive. HELP!!!!! 1.--Current Faults---->
Active Faults:
None
Logged Faults:
044:Front Right sensor output low
046:Front Left sensor output low
<-END Faults
Thanks Guy's!!!!! I'm building bumpers and a bunch of more product's for only discos!!!! I will post pictures later!!!!
Active Faults:
None
Logged Faults:
<-END Faults
