2000 Disco II headlights not working
Old Dec 19, 2009 | 07:06 PM
Princess's Avatar
Default 2000 Disco II headlights not working
I have a 2000 Disco II.
Hit a deer and needed to change out the passenger side headlight and side marker.
Since then the low beams don't work. High beams work and are aimed so poorly no-one flashes me at night.
I checked all fuses and all are ok. Checked 12 volts at the headlight connector and the high beams give 12 volts as it should. Lows have no 12 volts.
Any ideas? Both sides low beams do not light.
Old Dec 19, 2009 | 08:30 PM
Mrmerlin's Avatar
I would suggest that you replace the lo beam headlamp fuse/s, they can sometimes fail and still look good, is it possible that a ground wire may have gotten damaged at the headlight that was replaced??
It is also possible for both of the low beam portions of the bulbs to fail, but you said you dont get 12V when they are on low beam??
Old Dec 19, 2009 | 08:49 PM
Princess's Avatar
I checked the Usual fuses (And any fuse related in any way to lighting.) and the fusible links with the under hood fuse box.
Everything checked out fine.
Anyone have any other ideas???
Old Dec 19, 2009 | 09:23 PM
Mrmerlin's Avatar
did you replace the headlamp fuse???
Did you verify the wire integrity at the damaged headlight?.
Could the power wire for the lo beam have gotten cut??
Old Dec 20, 2009 | 11:46 AM
Princess's Avatar
Good idea about the wire being cut. But Both side low beams are out.
tsuyoi
Sep 22, 2020 10:37 AM
Rover Rog
May 26, 2019 12:33 AM
loganpendergraft
Feb 15, 2013 10:02 AM
RoverDiscoKiddo
Jan 29, 2012 09:45 PM
Street Wolf
Sep 27, 2008 08:58 AM
