2000 Disco with P0306 and P0300 code
Old May 7, 2009 | 08:10 AM
cellman01's Avatar
Default 2000 Disco with P0306 and P0300 code
Any ideas as to cause of P0306 and P0300 code. i have replaced plugs just about 500 miles ago. Think it could be the wires? Thanks for any help.
Old May 7, 2009 | 08:16 AM
What brand of plug did you install, how many miles on the engine, what octane gas do you use????
306, number 6 misfire is the most common of the rover misfires and yes, a set of 8 mm Magnacor wires will be the fix as long as you are not showing a #6 coil fault also.
Scott Weiland
Oct 16, 2013 01:15 PM
joatman
Jan 20, 2011 01:33 PM
mcneal
Jan 22, 2008 04:13 PM
Scott E
Aug 23, 2006 03:02 PM
