2000 Discovery
Old Sep 1, 2012 | 11:49 AM
Akumal's Avatar
Default 2000 Discovery
Had many misfire codes, put new plugs, new plug wires, plus changed out both front 02 sensors. Still have misfire codes. P1300, P1319, PO300, PO301, plus PO305. Car runs rough, getting to much gas i can smell it. No codes on MAF. Has no power, do not understand why its getting to much gas. Any thoughts. Thanks
Old Sep 1, 2012 | 01:08 PM
How many miles on the engine, what octane gas are you burning, whos plugs and wires?
Old Sep 1, 2012 | 01:46 PM
Akumal's Avatar
Thanks for responding Mike.
114,000 miles Plugs Bosch Platinum #4418 . Wires i'm not sure 7mm high temp. The last owner give them to me.
Old Sep 1, 2012 | 01:51 PM
Akumal's Avatar
On gas low octane, have not been using high octane,
Old Sep 1, 2012 | 01:54 PM
So I would start by using the gas you are supposed to be burning unless you live above 8000 feet.
Get rid of the junk 7 mm wires and go to the 8 mm STI or Magencor wires then see what happens.
Old Sep 1, 2012 | 03:30 PM
Akumal's Avatar
I will, thanks
Old Sep 1, 2012 | 09:12 PM
oilspotLR's Avatar
But first fill up with 93 octane and see what that does. IF you have a full tank of gas get octane booster and get that crap out of there!
Old Sep 1, 2012 | 09:19 PM
Octane booster does not work, save your money on that, just start using the proper grade of fuel.
Cheap plug wires will cause issues, use the ones Mike said.
duke051184
Jan 14, 2013 02:23 PM
Disco2Fever
48
Mar 12, 2012 12:39 PM
Airwolf1
Nov 6, 2006 04:27 PM
kennims
Apr 18, 2005 10:35 PM
Tote
Mar 4, 2005 10:34 PM
