2000 no water circulation?
Truck over heats explodes big hose underneath, but radiator fluid stays cold.
1. New thermostat
2. Head shaved and replaced.
3. New water pump
....any help on where to look would be greatly appreciated!
1. New thermostat
3. New water pump
I have heard of at least 3 people getting bad one from AtlanticBritish.
These problems are always tough, if the coolant is circulating properly the radiator should be hot.
But you say the coolant is hot, lower radiator hose explodes and the radiator is cold.
So that must mean a water pump that is turning backwards or the coolant is building up excessive pressure on the "cold" side of the radiator.
Either from a cracked block or head, bad head gasket or some other reason that I cant think of.
He didn't mean the pump is backwards. He meant that it is being SPUN backwards.
seamonkey1
Mar 29, 2011 08:50 PM
Team140
Aug 30, 2009 09:41 AM
