2000 no water circulation?
Old May 15, 2011 | 02:53 PM
preple's Avatar
Default 2000 no water circulation?
Truck over heats explodes big hose underneath, but radiator fluid stays cold.
1. New thermostat
2. Head shaved and replaced.
3. New water pump
....any help on where to look would be greatly appreciated!
Old May 15, 2011 | 03:49 PM
In the thread title you say its a 2000 but in your signature you say its a 1996.
Which is it?
Makes a huge difference.
Old May 15, 2011 | 05:12 PM
preple's Avatar
Oh, sorry, I have two.
Old May 15, 2011 | 05:33 PM
Thats better...
There have been a string of bad thermostats going around, where did you get yours from?
Old May 15, 2011 | 05:48 PM
preple's Avatar
Not sure, ill have to check? Where have the bad ones been coming from?
Old May 15, 2011 | 06:11 PM
I have heard of at least 3 people getting bad one from AtlanticBritish.
These problems are always tough, if the coolant is circulating properly the radiator should be hot.
But you say the coolant is hot, lower radiator hose explodes and the radiator is cold.
So that must mean a water pump that is turning backwards or the coolant is building up excessive pressure on the "cold" side of the radiator.
Either from a cracked block or head, bad head gasket or some other reason that I cant think of.
Old May 15, 2011 | 06:47 PM
preple's Avatar
Hmmm? How would the water pump be backwards? That one baffles me. Can it be checked by me?
Old May 15, 2011 | 07:26 PM
preple's Avatar
or for that matter, how would I go about seeing if the block was cracked, or not?
Old May 15, 2011 | 07:53 PM
DarylJ's Avatar
Improper serpentine belt routing.
He didn't mean the pump is backwards. He meant that it is being SPUN backwards.
discoboy
Dec 20, 2012 02:24 AM
seamonkey1
Mar 29, 2011 08:50 PM
lawson
Jun 1, 2010 12:31 PM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
