2001 cdl from d1 install. Cant get dash light to work.
Old May 15, 2023 | 09:24 PM
cerpindicular's Avatar
Default 2001 cdl from d1 install. Cant get dash light to work.
Edit: it would figure i would get it figured out almost immediately after making this post. Turns out i needed to hit it a little bit harder with my purse while locking it in. Got to do some more cutting on my cover plate tye i can get it all back together
Installing my shifter. Found the switch for the das light. If i cross the 2 wires to the switch dash light comes on. If i connect to switch without it installed and press the plunger light comes on on dash. If i install it the turn the cdl lock on the dash will not light up. I have the set as deep as i can with the jam nut. Even tried another switch no luck.
TRIARII
Mar 11, 2021 02:36 PM
Ivan0z
Apr 18, 2020 08:53 AM
TRIARII
Jan 6, 2017 08:28 PM
Savannah Buzz
Feb 10, 2014 10:52 AM
WaltNYC
Feb 1, 2011 11:20 PM
