2001 d2 Coolant top radiator connecting (plastic) pipe to hard Brake line mod
Old Feb 22, 2024 | 02:34 PM
Edm_disco2's Avatar
7th Gear
Default 2001 d2 Coolant top radiator connecting (plastic) pipe to hard Brake line mod
Hello all,
I tried searching the forum without the result I am seeking. I am a new owner of a 2001 D2, I am somewhat good at mechanic and DYI. The item 13 on the sketch below on my D2 is broken, previous owner has a lot of hose patches along the way. I want to replace the item 13 however I notice the pipe seem to be some kind of plastic material. I tested the 5/16 hard line galvanized pipe which seem to be the similar ID as the plastic pipe. my questions are:
1 - does anyone know if engine coolant will corrode the hard brakeline galvanize pipe?
2- has anyone tried this method? ( using hard brake line vs OEM plastic pipe)?
another method would be using the 5/16 fuel hose (50psi) to connect reservoir tank to the top of radiator.
please advised
Old Feb 22, 2024 | 03:40 PM
andino's Avatar
Most replace with a hose rather than another hardline. Not sure if brake hose will work but seems a lot easier to do maintenance with a soft rubber hose than a hardline.
Old Feb 22, 2024 | 04:03 PM
Extinct's Avatar
If you use hose make sure to use automatic transmission cooler hose. Fuel hose is not rated for the temperature nor pressure.
Old Feb 23, 2024 | 02:58 PM
nashvegas's Avatar
Or stating the obvious, just replace with coolant hose. An old D2 I purchased had a long narrow rubber coolant hose on it instead of the hard plastic line.
jastutte
May 17, 2022 03:01 PM
mark d
Dec 21, 2016 02:54 AM
CollieRover
Dec 21, 2015 12:00 PM
TRIARII
Nov 28, 2013 02:46 PM
VintageEros
Mar 6, 2008 08:48 AM
