2001 Disco 2 Horn not working
Hope someone can make some sense.
Horn stopped working for no reason.
1. Checked the Buttons they are ok
2. Checked 10A fuse - OK
3. Relay bases there is power
This is where it gets strange
4. Took the Horns out connected with Battery directly individually - does not work. Does not look like in need to Ground this.
5. There is no power at the connector
I can understand either #4 or #5 not working.
I found this post - but the pin numbers on Relay are #1 through #5 not pins 30 and 87 on the relay base the post says
https://landroverforums.com/forum/ge...working-45858/
Any help will be appreciated
Thanks
Thanks
I think the horn needs a ground to work. When they are bolted down they are grounded at that point. Do you get any power at the connector when the horn button is depressed? If you have power then it must not be getting a good ground. JMO D*
There should be a horn on each side. I know that horns can stop working internally for a variety of reasons. One of mine wasn't working and then the other one quit out of the blue, so I replaced the one nearest the battery with a set of air horns.
schwaggy
Apr 25, 2012 01:56 PM
johnkbl
Dec 29, 2008 11:15 AM
