2001 disco 2 no start blown fl 13
Old Jan 2, 2012 | 12:08 PM
Jrack's Avatar
Default 2001 disco 2 no start blown fl 13
Cant figure it out, girlfriends disco just got it back from the shop for replacing head gaskets. Ran fine on the way home. Now it wont start and keeps blowing the fl 13. No light flashing on the dash. Short in the ignition switch? All lights come on as expected when in the on position just nothing except the click of the relay when turned to the start position Any help would be appreciated
Thanks
Old Jan 2, 2012 | 09:32 PM
fl 13 -
If that is fuse link 13, (FL 13) in the underhood fuse box, it links to the light switch
If that is fuse 13 in the underhood box, that goes to the horns.
If that is fuse 13 in the passenger compartment - that goes to rear window lift relay.
Here's RAVE sheet on starting and fuses associated wih that.
File Type: pdf
Old Sep 13, 2012 | 03:08 PM
215luis's Avatar
4th Gear
Hey im having the problem fuse fl13 keeps blowing and it won't start any help would be great
Old Sep 13, 2012 | 04:58 PM
Bkreutz's Avatar
If you read the previous post by Savannah, which #13 fuse is blowing? is it the 30amp link fuse in the underhood box, the 10amp fuse in the same box, or the fuse under the dash on the drivers side? If it's the link, referring to the PDF that Savannah thoughtfully provided, that goes through the starter relay directly to the starter, if it pops immediately I'd be looking for a "shorted to ground" power wire. When you say it won't start do you mean the starter doesn't turn or that the engine will crank over but not start running (learned long ago that different terms mean different things to different people).
Old Sep 13, 2012 | 07:14 PM
215luis's Avatar
4th Gear
Yea its the 30 amp under the hood and no the starter doesnt do anything t
Turn the key lights come on normal but the starter doesnt do anything I then check the fuses and realize that fuse fl13 (sm) 30 was blown replace it and it blew again so yea I think its a shortage I just cant track it down ill take a look at the starter connections
Old Sep 14, 2012 | 12:32 AM
jfall's Avatar
Get a headlight.
Put wires on the headlight.
Put the other end of the wires from the head light under each contact of the 30A fuse.
As you have a short the headlight will light.
Now, start disconnecting stuff until the headlight goes out.
That will be your short.
Old Sep 14, 2012 | 04:38 PM
215luis's Avatar
4th Gear
Thanks I'm going to try that now just want to say thanks for all your help guys I'm kinda new to this forum and didn't expect this much soppurt thanks again
Old Sep 14, 2012 | 06:00 PM
This is a good forum that is well managed and supported by members that would help pull you out of a sticky situation on the trail or on the highway.
Old Sep 15, 2012 | 02:29 PM
fmasiddo@sbcglobal.net's Avatar
Default 2004 land rover won't start
Can someone help me with rover 2004. while driving the engine died. I sprayed carb cleaner inside the throttle body and started running until it runs out then died. I replace the fuel pump unfortunately it wasn't the problem. Then I check if there is power in the fuel connector (4 wires) white with pink stripe nothing when I turn the ignition to on position or to start it.
Andy M.
Old Mar 7, 2013 | 12:14 AM
215luis's Avatar
4th Gear
Okay guys I know its been a while but yesterday was nice out so I started working on the land rover after work the fl13 fuse box under the hood is to the starter after checking for shorts and couldnt find any I took of the starter (it has lifetime warranty from autozone ) so I took it in had them replace it with a new one pop it in replace the 30 amp fuse put the key in turn it and she lives again just thought I share for anyone having the same problem save some time
