2001 disco 2 vibration "front drive shaft"
I have been noticing a vibration only on acceleration above 30mph it has been getting worse. Also in reverse there is a slight chirping sound . My drive shaft is still factory. Is there any way to determine if it is the drive shaft. Can II take it off and drive and see if it goes away. Also if I do need a drive shaft can I just buy a $300 of ebay. I drive mostly on the pavement. If off road usually sand or very well kept hunting roads.
If you have the CDL you can remove the drive shaft lock the cdl and drive it home.
Grew up in a service department so I know if something sounds different get it checked out. Do any of yall know if a 33.9/11.6r20 will fit with the 3" terrafirma? I know it's not your style. It's a Florida thing. I have on order 33/10.9r20 but have to wait 3 to 5 weeks to get the wheels made with the correct offset to avoid having spacers and may call and go bigger. No serious off reading no rocks no hills it's florida.
