2001 Disco II Front Bumper Bolt Pattern
Old Jan 2, 2019 | 10:55 AM
DivebombInc's Avatar
Default 2001 Disco II Front Bumper Bolt Pattern
Well, my son did a number on my DII so I have to go haul it back home. I have a tow bar already that I'm going to use, but I need to make some brackets that I can bolt to the frame were the front bumper "was". Does anyone have the bolt pattern where I can bolt the bracket to the frame? Basically need to make 2 of these and I'd like to drill the holes before I make the drive.
Old Jan 2, 2019 | 01:33 PM
Sandman614's Avatar
You would need a bracket that will bolt onto the side of the frame as the bumper is held on by 2 through bolts.
Old Jan 2, 2019 | 04:50 PM
Thanks!
Looks like about 2.5"?
And about a .375" Bolt?
What about from the front hole to clear the end of the frame?
Old Jan 2, 2019 | 04:56 PM
Sixpack577's Avatar
Won't you need an "L" shaped bracket instead?
So it can drop below the frame and bumper, and extend to the front?
Old Jan 2, 2019 | 05:32 PM
Well, my son made it easier by making the front bumper go away. So I just need to bolt to the sides of the frame and extend far enough to clear the end of the frame plus about an inch.
Old Jan 2, 2019 | 09:21 PM
Sandman614's Avatar
Thanks!
Maybe 2-5/8", probably best to slot one of the holes. From the center of the bolts to the front of the frame is right an inch.
vishrb
Jul 30, 2017 06:59 PM
adolfojbonilla
May 2, 2016 11:31 AM
Disco Fuego
Feb 2, 2009 12:03 AM
JEFF
Apr 19, 2007 09:47 PM
pwag
Jul 23, 2006 11:14 PM
