2001 disco, no spark, no fuel pressure.
Old Dec 22, 2011 | 07:35 AM
mydisco03's Avatar
Ok So i will try to switch those spacers today and see what happen.... When I turn the ignition key, The fuel fump never build pressure, Infact theres no power there for the fuel pump. "fuel pump is in good condition"........ I need to get a volt meeter =/
Old Dec 22, 2011 | 07:48 AM
mydisco03's Avatar
About the wire harnes: someone pull that already, maybe that truck was in a shop or something before.... Ok letme ask you guys this: If the crank shaft is disconected, theres no signal to the ECU and for that reason theres no spark right? Ok But the fuel pump need to build pressure no matter what right? Or the ecu is cutting the fuel power too bcz the crank shaft sensor is been disconected? Now, in the case of having the crank shaft plug in but the spacers in the wrong positions, should I have power on the pump at least for 30 seconds? Bcz im not even getting 30 seconds from the fuel pump........ Today I will work on her, so let's see what the deal is.....Thanks Guy's!!!!!!!
Old Dec 22, 2011 | 07:51 AM
mydisco03's Avatar
Where is the main relay? engine bay? I try swaping relays from place to place but luck...
Old Dec 22, 2011 | 09:39 AM
It is in the underhood fuse box. Drawing sent earlier in post. Ignition key turns it and other things on. Main relay powers up sensors, etc. It also enables the starter relay and the fuel pump relay, but those are switched on by the BCU or the ECU, which ground them to operate. You'll need the RAVE, it is possible to do this on line by exchanging messages, but it is like playing chess by mail... takes a while. Relay info attached.
File Type: pdf
Old Dec 22, 2011 | 04:37 PM
mydisco03's Avatar
Alright Guy's!!!! I crank the DII today =D Yeiiiiii !!!! it turn out that Whoever work on this LR before me was a complete idiot LOL... The crank shaft sensor was all wrong, He put the aluminum housing first then the spacers then the plastic sensor.... Im glad savanna post the right way to doit !!!! Thank's one more time guy's!!!!
ADDAM
Mar 10, 2012 12:26 PM
appjcr
Dec 19, 2011 06:23 PM
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
appjcr
Oct 13, 2008 09:06 AM
